Author Topic: Just installed for 3ds max design 2015 - dll error  (Read 7897 times)
ES1947
« on: July 15, 2014, 12:54:43 pm »
Just downloaded ForestPackPro424 and selected C:\Program Files\Autodesk\3ds Max Design 2015\ as path, but when I start 3ds max design 2015, I get the attached error.
Has anyone a solution for this?
Re: Just installed for 3ds max design 2015 - dll error
« Reply #1 on: July 15, 2014, 01:22:22 pm »
It looks like 3ds Max can't find some of libraries used by the plug-in. As all of them are part of 3ds Max they shouldn't be missing, but please try to install the Visual C++ Redistributable for Visual Studio 2012 Update 4. Please tell us if that solves the issue. Thanks in advance.
Kind regards,
ES1947
« Reply #2 on: July 15, 2014, 01:28:00 pm »
Hi Michal
I just downloaded the file. I get the attached message.
I'm not sure if I should use the repair function?
ES1947
« Reply #3 on: July 15, 2014, 01:43:18 pm »
Well tried to use the repair function - still get the error.
« Reply #4 on: July 15, 2014, 01:48:57 pm »
Yes, please use the Repair option. If the problem persist, please take a screenshot of <maxdir>\plugins\ForestPackPro.dlo file Properties. Just to double check, that the correct file was placed into plugins foder. Thanks in advance.
Kind regards,
ES1947
« Reply #5 on: July 15, 2014, 01:54:11 pm »
Screenshot
« Reply #6 on: July 15, 2014, 03:45:02 pm »
It seems the file ForestPackPro.dlo is not correct. It matches with the dlo of Forest Pro 4.1.5 for Max 2014.
Please, try this:
1.- Close Max.
2.- Remove the file ForestPackPro.dlo.
3.- Reinstall Forest.
That should solve the problem.
ES1947
« Reply #7 on: July 15, 2014, 04:05:49 pm »
Hi Carlos
A reinstall seemed to fix the problem.
