Author Topic: Laubwerk Integration  (Read 3343 times)
FC2603
« on: June 21, 2023, 06:26:44 am »
I have a number of the Laubwerk libraries and had a problem with the most recent one I installed where it separated it out as a new library, so I decided to uninstall every pack and start again to reintegrate with Forest Pack to make sure all of the assets are up to date.
Now when I install all of the packs there are no English names listed (along with the latin) when I open from the Forest Pack library like they used to have - see pic 1.
Then when I choose a tree I used to be able to see the different options - for example 'Silver Birch (Variant 1 Young)'. Now there is no text telling me which one it is - see pic 2.
When I import one of the trees from the Forest Library it picks up half of the name so shows the geometry as '(Variant 1 Young)' without the tree name which is going to be very time consuming going through renaming everything.
As a workaround, the Laubwerk Plant Library Browser does show all the names so can import and select that way but it's a lot simpler to do it straight from the Forest Library.
Any ideas how to fix this?
Re: Laubwerk Integration
« Reply #1 on: June 21, 2023, 10:08:54 am »
I'm sorry to hear, you're facing these troubles, but I‘m afraid, that since a time ago, the integration with our plug-in is done completely by a corresponding third-party company that provides their vegetation packages (in this case Laubwerk GmbH) and we keep preparing it just for our The3dGarden plant collections. I would recommend you report it directly to them as we can‘t do much more in this case. Thanks for your comprehension.
FC2603
« Reply #2 on: June 21, 2023, 01:54:45 pm »
No problem, thanks for the info.
I've been in touch with Laubwerk and it's a known problem with their more recent releases. Hopefully there will be a fix soon.
