Author Topic: FP Crashing Max in Material Editor  (Read 2798 times)
Dustin
« on: August 12, 2023, 08:09:14 am »
With material editor open, I drag the multi-subobject material over to the Material slot on FP object as an instance and Max immediately crashes. Every time.
Re: FP Crashing Max in Material Editor
« Reply #1 on: August 12, 2023, 08:13:14 am »
You don't need to assign a multi-material to Forest. It creates and assign itself automatically.
Just assign the materials to source objects.
Anyway, please send us the minidump to check what is causing the crash.
Dustin
« Reply #2 on: August 12, 2023, 08:35:07 am »
I am aware that FP automatically creates its own and if Im lucky with a supported engine, it will work. I have already created another set of materials as multi-sub due to the un-supported render engine. I would assume it would be just as easy to use my existing m-sub? I may have fixed it by updating FP. Either that or before dragging my multi-sub over to FP, I made sure I had the same amount of material ID slots as the one that FP created.
As far as assigning materials to source objects, if you mean un-hiding and un-freezing source objects, that seems more labor intensive that just dragging the material to the FP slot.
EDIT: Unfortunately it is presenting more problems that Ive run into before with un-supported render engines. It consistently tells me that There are too many faces in the scene even with the parameter cranked up to 9999million. Ill have to resort to TyFlow for scattering for now. Ty.
« Last Edit: August 12, 2023, 08:57:36 am by Dustin »
« Reply #3 on: August 14, 2023, 09:50:13 am »
You can assign your own multi-sub manually, but it will be overriden by the generated by Forest. To avoid that, you should turn off Geometry->"Consolidate Materials".
But as said, we suggest to not use this procedure, and let to Forest to handle the multi-sub by itself.
Alternatively, you can assign the materials to "Geometry->Material". There is an entry for each source object, and it overrides the object's material.
Since one or other method are time consuming, the better approach is to prepare your object and materials only one time, and save them in the library as presets.
What render engine do you use ?
You can set any limit (as Max.Faces) to zero to disable it.
Anyway, generating an huge geometry is not a good idea, because it is very likely that Max or the render engine crashes, due to overload.
In these cases, you can use Forest Tools to generate standalone objects.
Dustin
« Reply #4 on: August 15, 2023, 03:21:31 am »
Thanks Carlos, these seem like new options that have been made available in recent versions? Most of these options were un-heard of a couple of versions ago. This might help alot.
I was trying Centileo Render for 3dsMax. Its a promising engine with a few caveats. Very fast and wonderful displacement. Ill check into generating standalone objects.
« Reply #5 on: August 16, 2023, 07:36:15 am »
Not really. All options i mentioned are in Forest for quite some time.
But it's normal to not know all Forest possibilities. There are many options.
No, this render engine is not supported currently.
You would ask to them to support our plugins, we'll be glad to help to their developers.
