Author Topic: Gravel on spline, move verties in the Z - problem generating mesh  (Read 4540 times)
CT3320
I created a closed spline in top view for a gravel driveway in front of a house. but driveway is on a slope so I move a few vertices in the z (so now spline is not a flat 2d shape) but when i go to create a forest gravel it just hangs, hitting Esc will bring back the scene so it doesn't crash me out of max. but I really need the gravel on a slope
should i just create a surface and use that rather than a spline
thanks
Tom
Re: Gravel on spline, move verties in the Z - problem generating mesh
« Reply #1 on: April 16, 2019, 08:36:12 pm »
but I really need the gravel on a slope.
thanks
Tom
Yes You need to use surface if You need gravel on sloped surface.
CT3320
« Reply #2 on: April 17, 2019, 12:29:39 pm »
got is sorted with a surface.
so splines are out when they have xyz coords, is this just for gravel or all items
cheers
T
« Reply #3 on: April 17, 2019, 01:02:10 pm »
if You use spline- forest will be placed flat in the highest position of the spline.
Using surface is always good idea. It opens up many possibilities.
