Author Topic: Latest Forest Pro crashes 3ds Max 2015 / MentalRay  (Read 4365 times)
suppenhuhn
« on: June 16, 2015, 07:09:19 pm »
i've updated the Forest Pro / Railclone Pro to the latest version yesterday - now Mental Ray crashes every time trying to render the scene.
 The error is :
 DB   0.5    263 MB fatal  041052: accessing unknown tag 0x5
Guess it has something to do with Mutli-Submaterials ( not sure )
After deleting the Forest Objects i renders fine - but it's not what i desired, of course.
Using Max Design 2015 64bit on WIN7 Pro
Re: Latest Forest Pro crashes 3ds Max 2015 / MentalRay
« Reply #1 on: June 17, 2015, 08:52:26 am »
Hi, i'm testing several of our tutorial scenes but i cannot reproduce the error. Please, would you send us a stripped scene to support@itoosoft.com ?
suppenhuhn
« Reply #2 on: June 17, 2015, 12:05:43 pm »
I'll send you the forest-object's-only scene.
« Reply #3 on: June 17, 2015, 05:55:50 pm »
Thanks for the scene. We have identified the problem and working on a fix.
suppenhuhn
« Reply #4 on: June 18, 2015, 09:14:42 am »
Great! Multi-Submaterials?
« Reply #5 on: June 19, 2015, 05:05:29 pm »
Not really. It was caused by a workaround to fix a Mental Ray bug. Unfortunately the workaround was not implemented correctly.
I think we have fixed the problem. You can find the patch attached.
To install it, just replace FShader3.dll in <maxdir>\NVIDIA\shaders_autoload\mentalray\shaders. It everything is ok, we'll include it in the next FP update.
suppenhuhn
« Reply #6 on: June 26, 2015, 06:49:24 pm »
Thank you for the news - i'll try it after our current project is finished!
PL9258
« Reply #7 on: June 30, 2015, 12:46:42 pm »
I'm having this issue too. I have installed the attachment but still having the problem in 2015. (the attachment fixed the problem in 2016 BUT my lighting doesn't work in 2016, different issue..) Some of my forest items do work; forest fir tree and grass clumps are not working but maple tree and rocks, for example, work fine. Also if I put the fir tree in a scene by itself it renders just fine but when put into my scene I get the same error as suppenhuhn reported. Do you have any ideas what might be the problem?
« Reply #8 on: June 30, 2015, 01:15:59 pm »
We finally could reproduce the crash here. But it happens also using FP 4.3.7 for 2015 (binaries are compatible with 2016). So, it seems there are several problems involved here.
Apologies for any inconvenience. This issue is requiring a lot of trial and error tests.
« Last Edit: June 30, 2015, 01:43:16 pm by iToo »
« Reply #9 on: July 02, 2015, 01:48:17 pm »
I've created a new thread, to unify all cases related with Mental Ray and FP 4.4.0. Please, follow the thread here.
« Last Edit: July 02, 2015, 06:15:15 pm by iToo »
