Author Topic: Light and group scatter issue  (Read 10651 times)
Sketchrender
« on: July 24, 2024, 12:33:19 pm »
when i group a light with the object I have built to set the light in, and use Forest pro to scatter it on a line, I can not adjust the light if I group it with the object, and then scatter and un group the parent light , all the scattered lights disappear.
How do I get around this issue?
Thank you
phil
Re: Light and group scatter issue
« Reply #1 on: July 24, 2024, 12:46:29 pm »
Hi Phil,
After using the Ungroup command, you will need to reselect the object used under Geometry > Custom Object within the ForestPack plug-in, as the Ungroup operation breaks the link.
I hope this helps.
