Author Topic: Maya Import Error  (Read 5046 times)
NR4273
Maya Import Error
« on: April 17, 2012, 10:16:46 pm »
Hi All,
I modeled a surface in Maya to use for terrain, and imported into 3ds max via a FBX file. In Max, it exists as an editable poly with a turbosmooth modifier. When I try to use this as the surface to generate my forest, i get very strange results. The planes extend out past the sides of the surface, and the trees don't generate properly at all.
Any suggestions? Thanks!
-Joe
Re: Maya Import Error
« Reply #1 on: April 17, 2012, 10:23:57 pm »
Please, try applying a Utilities->Reset Xform, usually that solves most of the Surface issues. In some cases, also would be needed to fix the normals using a Normal modifier.
