Author Topic: Octane Render 1.13 / Max Design 2014 / Forest Pack Pro 4.0.3 - Crashing  (Read 5986 times)
BKE
When I add grass, then hit refresh on my Octane Render window, the grass does not appear. In fact, as long as the original Forest Pack Pro objects are on the default frozen layer, the grass proxies do not show up either.
When I thaw the default frozen layer that the Forest Pack Pro objects are on, my proxies reappear. When I choose to refresh the Octane Render window, Max crashes every time.
Is there a work-around for this? I am in need of help to keep moving forward on my project!
Thank you - Brian
It works fine here, using Octane 1.10 which is the stable version. The grass is rendered even on the hidden layer and there are not crashes.
I suggest you post this issue in the Octane forum. v1.13 is a test version and may be these problems have not been reported yet.
BKE
Thanks, Carlos! Just to verify: you are using Max Design 2014?
Yes, Max 2014 (not Design, but should not be differences).
BKE
Good to know! Thank you - It is always good to eliminate variables.
