Author Topic: Low brick wall  (Read 3262 times)
FU1154
Low brick wall
« on: December 05, 2023, 11:09:47 AM »
Hello, I would like to know how to make a wall like that.
I can get the outline but how do I do the inside?
 Mount bricks on a surface?
thank you very much
« Last Edit: December 06, 2023, 09:47:14 AM by FU1154 »
Re: Low brick wall
« Reply #1 on: December 06, 2023, 01:11:37 PM »
HI,
Thanks for the question. This might be quite challenging for RailClone because it's necessary to fill a complex  area with geometry that doesn't look as though it it tiles. If however, it's more like regular bricks that are surrounded by larger areas of concrete, then you might be able to do something like the attached file which uses the same style by raises it on the Z axis and rotates the array by a further 90 degrees. For more irregular bricks you could always pre-compose some stones shapes like in this post
I hope that helps, please let me know if I can do anything further,
FU1154
Re: Low brick wall
« Reply #2 on: December 06, 2023, 01:38:26 PM »
Thanks ! i don't have max 2024 is it possible in 2023 ?
Re: Low brick wall
« Reply #3 on: December 06, 2023, 02:41:58 PM »
Apologies, here's a file saved back to previous Max versions.
Best,
