Author Topic: Reference not working with pivot (FP 7.3)  (Read 3587 times)
RealViz
    • RealViz
« on: February 02, 2022, 03:00:02 pm »
I've now noticed that FP does not respect the pivot manual offset of the ref. object in reference mode. The default pivot is still used.
Re: Reference not working with pivot (FP 7.3)
« Reply #1 on: February 02, 2022, 03:03:42 pm »
Hi! It should work if you reset the XForm of the reference objects
Best,
RealViz
    • RealViz
« Reply #2 on: February 02, 2022, 03:16:25 pm »
But that unfortunately ruins the object's rotation :-(
RealViz
    • RealViz
« Reply #3 on: February 02, 2022, 03:17:03 pm »
I believe that previously this function worked normally without resetting xform.
« Reply #4 on: February 02, 2022, 03:34:28 pm »
I just checked this in Forest Pack 6, and it would appear to be the same as Forest Pack 7.3. I'll mention it to our dev team, but it may be something Max related over which we have little control.
RealViz
    • RealViz
« Reply #5 on: February 02, 2022, 04:50:27 pm »
Thanks, maybe I'm just remembering it wrong. The best solution is to select the ref. obj. and then rotate/move them in the local.
