Author Topic: Forest Listener  (Read 36277 times)
Bobby Parker
Forest Listener
« on: May 30, 2024, 07:21:23 pm »
I can't see the full Forest name. I can only see "Forest" and I can't extend the column.
Re: Forest Listener
« Reply #1 on: May 31, 2024, 08:50:11 am »
Hi Bobby,
You can either resize the Forest Lister window to display the full Forest object name or remove some column(s) via the Lister Options window. I hope this helps.
CharlyRT
Re: Forest Listener
« Reply #2 on: June 01, 2024, 09:26:50 pm »
hi
in the lister from the beta if i tried to select multiple elements holding shift most of the time it just select one or two, in previous versions i could select all of them
sometimes if i select all i cannot select just one, its a little buggy
I attach the behavior in previous versions and beta
« Last Edit: June 01, 2024, 11:16:47 pm by CharlyRT »
