Author Topic: convert to editable poly  (Read 29354 times)
jpmartin
« on: December 10, 2013, 07:57:12 pm »
Is there any way to convert/collapse the mesh created by Railclone lite into an editable poly or mesh once we've got everything setup as we'd like it to?
Re: convert to editable poly
« Reply #1 on: December 11, 2013, 08:42:30 am »
No, that feature is not available in Lite version. It can be done with RailClone Pro instead.
You can see the differences between Lite and Pro here.
RobH2
  • Who is staring at the sea is already sailing a bit
    • NVision4D
« Reply #2 on: May 08, 2015, 07:55:18 pm »
Ok, so how do you do it in the Pro version? I can't figure it out and/or it's not working.
ForestPack Pro 6.3.1, RailClone 4.2.13, 3ds Max (Max 2024), GIGABYTE X570 AORUS x570 Master Motherboard, RTX4090, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, Sabrent Rocket NVMe 4.0 M.2 drives
« Reply #3 on: May 09, 2015, 08:42:20 am »
Please, check this.
YH6509
« Reply #4 on: August 26, 2020, 10:15:26 am »
The answer is most likely that you need to ensure that your Railclone model is set to Mesh in the Display>Viewport settings before converting to edit poly.
