Author Topic: Railclone colour map - by element shading  (Read 21640 times)
RG1597
« on: August 20, 2020, 12:43:33 pm »
Anyway to use RCclour map on a per element basis?
I have a very large area to cover with paving. I has a 10mx10m pattern repeat, but there will be material changes within that (made of slabs so I don't want every 10m square to look like every other one). Using individual slabs will become very unweildy, so I'm using the 10x10m geo repeat.
A quick test, attached suggests that RCColour map works on a per-object basis, and there's no option to switch to per-element as with FP colour.
I know the mods will be loathed to answer this, seeing as I'm a lowly RClite user. I do use FP pro and can't justify RC pro to my seniors at the moment, when this is doing everything I need (well, up until now!)
Re: Railclone colour map - by element shading
« Reply #1 on: August 20, 2020, 02:19:19 pm »
RC color works on Segment.
There are multiple ways to solve it. Shifting UVs is the easiest.
RG1597
« Reply #2 on: August 20, 2020, 03:12:05 pm »
Thanks for confirming. I've found another way around it using VRayMultiSubTex
