Author Topic: Corner and cornice problem  (Read 73578 times)
BB3059
« on: May 23, 2025, 12:07:19 pm »
Hi, my goal is to create a cornice like this one, with a simple profile. The thing is when i put it on a spline with a round corner I can't seem to find a solution to make the corner match the rest of the cornice as you can see in the second screenshot.
 I tried with bevel corner, but can't seem to find a solution.
Thanks a lot
Re: Corner and cornice problem
« Reply #1 on: May 23, 2025, 01:04:51 pm »
I would suggest changing the Y Alignment of the used Segment to either Bottom or Top, and then readjusting it using the Y Offset parameter of the Generator. I hope this helps.
BB3059
« Reply #2 on: May 23, 2025, 02:25:35 pm »
Thanks for your answer, this actually doesn't work, it works i already had it set to pivot for y alignement. It does work on the top alignement but then it's on the wrong "side" of my spline...
