Toggle navigation
Login
Register
RailClone
RailClone Lite
Decorative tile pattern
« previous
next »
Print
Pages: [
1
Author
Topic: Decorative tile pattern (Read 163698 times)
anthonyhartleydenton
Newbie
on:
February 08, 2024, 02:58:54 pm »
Hi All
new to the forum and was wondering if anyone might be able to help. I am using Railclone preset. the pattern and colour are perfect but I need to get the half-moon feature tiles to run in a 3, not a 2 and only in the location on the drawing.
Could anyone point me in the direction of the parameters I should be looking at?
thanks, Tony
Logged
ITOOSOFT
Hero Member
Re: Decorative tile pattern
Reply #1 on:
February 08, 2024, 03:19:00 pm »
Hi Tony,
The easiest way would probably be to use two
Clipping Areas
(to use these "decorative tiles" just at the specified location) - either within two individual RC objects or within two Generators within one RC object. You can adjust the number of "decorative tiles" by setting the "
Decorative Tile Y Count
" parameter. I hope that helps.
Logged
Newbie
Reply #2 on:
February 08, 2024, 04:40:12 pm »
is there not a way to do it by modifying the settings of the template already in the library? I have it applied to all the buildings already so it would be easier. creating separate clipping areas across multiple facades and 14 buildings will be time-consuming. thanks T
Logged
ITOOSOFT
Hero Member
Reply #3 on:
February 09, 2024, 08:37:03 am »
Well, if "decorative tiles" should always be placed at the same height, you can try raising the "
Standard Tile Y Count
" value (which drives the counter in the
Sequence
Operator) until it fits your needs.
Logged
Newbie
Reply #4 on:
February 19, 2024, 05:53:17 pm »
Hi Michal thanks for the help. so I've got the following and two queries if you might be able to help.
1. how to i get 3 rows of tiles?
2. how do i shunt the 3 rows downward to align where shown. If tried changing the y count up when the numbers gets too small more decorative tiles keep appearing top and bottom.
thanks again T
Logged
ITOOSOFT
Hero Member
Reply #5 on:
February 21, 2024, 09:21:22 am »
You can adapt the style a bit to support two different
values by connecting the corresponding
Random
Operator to the
Sequence
Operator (and optionally exporting the
Counter
parameter to the UI) as shown in the attached screenshot. I hope that helps.
Logged
Newbie
Reply #6 on:
February 22, 2024, 04:53:35 pm »
hey thanks for that
also how to i pipe in the second Y count?
how do i export to the UI?
Logged
Newbie
Reply #7 on:
March 05, 2024, 01:55:29 pm »
Hi All another question relating to hanging tiles.
My decorative hanging tiles stop a full tile short of the end. How would I make them run to the corner, please?
thanks in advance T
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Lite
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
