Author Topic: Wooden broadwalk in wetland  (Read 36287 times)
EM2864
« on: March 01, 2017, 11:31:36 am »
hi all!
I would like to learn how to build a wooden broadwalk with railclone lite. I want my broadwalk to have different width. Let me illustrate it with some images and referances. Thank you all in advance!!
Re: Wooden broadwalk in wetland
« Reply #1 on: March 01, 2017, 12:34:07 pm »
A recommendable way would be to create and use a "centre" spline as the X Spline together with a closed spline made from "border" splines as a Clipping area. There are many ways how to further randomize the style - like for example by driving the X Fixed Size by a Random Parameter generated on Segment.
EM2864
« Reply #2 on: March 03, 2017, 07:55:11 pm »
great!!! Thank you very much...
And can you please show me how to randomize color of the segments... I tried but the result was a bit unexpected :D
« Reply #3 on: March 06, 2017, 05:29:31 pm »
You're welcome. The Material Operator is designed for these purposes (it uses a designated Material ID from the input segment and replaces it with a new value identified in the From / To range). Just take in mind, that this operator is only fully compatible with V-Ray. To use with other renderers it is necessary to disable Display > Use Instancing Engine.
