Author Topic: Railclone Library  (Read 4207 times)
williamyu1988
Railclone Library
« on: April 19, 2016, 06:06:25 pm »
i just updated to the newest version, but it seems to not have any new Library?
i see a wish list but is there somewhere i can download?
any updates on the library???
Re: Railclone Library
« Reply #1 on: April 19, 2016, 06:28:24 pm »
Thanks for contacting us. RailClone 2.6 has the same library as RailClone 2.5, there a were no additions in this version. In the next release of RailClone we will be updating the libraries so if you have any suggestions for content, please let us know in the wish list which you can find here:
http://forum.itoosoft.com/index.php?topic=1749.0
Many thanks,
williamyu1988
« Reply #2 on: April 20, 2016, 09:35:16 am »
Hi Paul thanks for the quick reply,
i have another question in the past version, i can CTRL+V to clone an Railclone
i have notice the new version can't do so?
is there a way to do it? or what do you suggest?
« Reply #3 on: April 20, 2016, 12:44:53 pm »
Is 3ds Max Crashing when you use CTRL+V to instance it or it's just not working?
If it's crashing this may be related to an intermittent bug that seems to be related to a problem with the Max SDK. We're trying to find a workaround. As a solution in the meantime you can make an object instanceable by Using Ctrl+V first to make a copy (you can delete this afterwards is you want), and then Use Ctrl+V to Instance. Alternatively holding down shift while you you move the object also works.
I hope that helps,
Paul.
