Author Topic: Nested Railclone segment lost in render when viewport mode set to boxes  (Read 5127 times)
shiyan lin
Hi,It's my first post here.
I think I need to post a bug here ,the bug was just like the name of the topic.
1. I use a corona proxy and a railclone object nested in one segement.
2. I turn the railclone viewport mode to boxes
3. I turn on the interactive rendering and find the railclone object which nested in segement was lost in VFB.
4.When I stop the render,everything back to normal.
I am not good at English,hope the scene file attached might helped.
3dsmax 2018 + Corona Render 2.0 + Railclone 3.2.0
Best regards.
« Last Edit: October 07, 2018, 09:15:04 pm by shiyan lin »
Re: Nested Railclone segment lost in render when viewport mode set to boxes
« Reply #1 on: October 08, 2018, 02:41:37 pm »
Sorry to hear, you’re facing these troubles. Would you mind to attach also the proxy object (Brick_001.cgeo)? Thanks in advance for any further details on this issue you can share with us.
shiyan lin
« Reply #2 on: October 08, 2018, 02:46:27 pm »
sorry,file attached.
« Reply #3 on: October 08, 2018, 05:01:20 pm »
Big thanks for all provided files. It doesn’t seem to be related to the selected view-port mode, but nested objects shouldn’t have the Display > Render > Use Instancing Engine option enabled in order to build the “top level” object correctly. The main RC object “RC_Brick_Office” can use this option to keep the instancing. Hope that helps.
shiyan lin
« Reply #4 on: October 08, 2018, 05:10:47 pm »
Ok, when nest a railclone object,instance engine should turn off. I got it,thanks for taking time answering my dumb question.,big thanks.
    I have a question though: Is instance engine being used to speed up parsing process of rendering or what? I am quite new to 3dsmax,but really love FP and RC,really don't know what's instance engine all about. The only little thing I knew about instance engine is that the instance engine is not fully compatible with corona render...
« Last Edit: October 08, 2018, 05:13:45 pm by shiyan lin »
« Reply #5 on: October 09, 2018, 08:10:46 am »
Hi, You asked important question. And I could not described it better then Paul described it in this post.
