Author Topic: Window  (Read 7283 times)
Sergey_Dobrij
Window
« on: July 11, 2017, 09:06:47 pm »
Hi, everybody! Help to solve a problem. Excuse for my English
http://prntscr.com/fug6vs
http://dropmefiles.com/w0VeV
Re: Window
« Reply #1 on: July 12, 2017, 01:23:51 pm »
That's because Pivot Points are used for the Z Alignment, but these aren't aligned. Moving these under Adjust Pivot - Adjust Pivot Only correspondingly fixed is. Attaching screen-shots and the modified scene. Hope that helps.
Sergey_Dobrij
Re: Window
« Reply #2 on: July 12, 2017, 03:01:29 pm »
Thanks!!!  :)
Sergey_Dobrij
Re: Window
« Reply #3 on: July 12, 2017, 03:23:20 pm »
Once again thanks, everything has turned out).
https://prnt.sc/furq3w
Now I want to create a horizontal profile and handles. If there is an opportunity, help me please. Thanks!
Re: Window
« Reply #4 on: July 14, 2017, 03:44:25 pm »
Our Parameterising Windows tutorial shows a possible work-flow for similar cases. Also, I would suggest you to check the Parameterising Windows with RailClone thread on our forum, where you can find several tips and sample scenes showing possible style set-ups. Hope that helps.
Sergey_Dobrij
Re: Window
« Reply #5 on: July 16, 2017, 11:03:39 am »
Thanks!!!  :)
