Author Topic: 4.0.9 crash when editing material when IPR mode is on  (Read 3293 times)
muoto
« on: October 27, 2019, 02:35:38 pm »
When editing a material while IPR mode is on and rendering a railclone object leads to max crashes
Re: 4.0.9 crash when editing material when IPR mode is on
« Reply #1 on: October 28, 2019, 08:43:15 am »
Which version of Vray/RailClone are You using? Is it consistent or random crashing?
If possible, please send us the minidump when Max crashes or better a minimal max scene and steps how to reproduce the crash. It would be most helpful to find the problem.
Bruce Hart
« Reply #2 on: November 09, 2019, 11:56:43 am »
I have observed this also.
Here's a link to a Video capture:  https://www.dropbox.com/s/fi63qcj5ie5fus5/RailClone_Vray_IPR_1.mp4?dl=0
In this case the crash occurs when "use segment material" is checked.  I'm using 3DS max 2020.2, Vray Next 4.10.03.   I initially saw this occur with RailClone 4.09, but 4.1 has the same issue.  Also of note in the video - the Railclone object disappears.  You will also note that the crash does not occur immediately, but after several adjustments of the material.   Max file attached.
Hope this helps
