Author Topic: Equal spacing problem  (Read 3072 times)
maknev
« on: September 25, 2019, 04:22:12 pm »
Hi guys, what am I doing wrong?
I am just making a simple slat wall, and trying to keep the start and end positions at the start and end of spline, and just have equaly spaced slats in between (evenly).  The first method with Default padding doesn't work, because the whole railclone slides beyond the spline.
Second method with Start, End and Evenly, also doesn't seem to work because the spacing is not kept even towards the Start and End points..
Is there some simple solution that I am missing?
Art
maknev
Re: Equal spacing problem
« Reply #1 on: September 25, 2019, 04:31:43 pm »
Oooops! silly me!
Just had to figure out correct spacing!
« Reply #2 on: September 25, 2019, 04:42:32 pm »
You can use Center Alignment For the Segment and Limit Padding (Half Size of the X Size)
Evenly Adaptive set to ON
Both modes will work fine  Distance and Count.
Best Regards
« Last Edit: September 25, 2019, 04:46:28 pm by Dragan »
maknev
« Reply #3 on: September 25, 2019, 05:16:57 pm »
Cool, thanks for including the file!
I will take a look, sounds like a nice solution!
