Author Topic: Railclone corner segment not facing the correct way on inner corners  (Read 14933 times)
chrisc0le
Hi, hopefully someone can explain this to me as I've used convoluted work-arounds in the past for this issue.
Please see attached image to explain the issue. A single corner object works on what I call outward facing corners, but the inward facing corners are the wrong orientation to align with the default wall segments. Hopefully this is a simple fix.
In fact I'm having issues aligning all parts of a quixel/ megascans wall collection. The segments available are in white below the green RC preview.
It would be great if someone has done this before & could explain how it all fits together.
Chris
« Last Edit: October 11, 2024, 11:48:58 am by chrisc0le »
Re: Railclone corner segment not facing the correct way on inner corners
« Reply #1 on: October 11, 2024, 12:01:47 pm »
Hi Chris,
You can position the correctly rotated Segment using the Vertex Angle within the Conditional Operator. I've attached a sample scene that demonstrates a possible style setup. I hope you find it helpful!
chrisc0le
« Reply #2 on: October 11, 2024, 01:57:12 pm »
Ahh I wasn't far off. I've been trying to use a conditional operator, but not quite like this.
Many thanks Michal
