Hi there.
I'm getting stuck when trying to use the A2S generator on a facade.
It's a simple grid system where the default segment is the windows between the grid (I'll attach images and scene)
But no matter what I do I can't get the default segment to be populating all empty spaces between the grid. If I only use Y evenly or only X Corner+X Evenly it works, but not all options
I've been trying this for a while now and I can't seem to figure out what is wrong or how it should be done.
First I thought it might be because I didn't use the different start segments(since it's a closed spline), but this didn't seem to have an effect. I've tried different alignments on the segments, I've tried to enable and disable extend to side on corners and evenly options. I've basically painted myself into a corner and I can't figure it out.
I think this is a user error, but since I can't get there myself I'm asking for some help here. Hope it's an easy mistake to fix
