Author Topic: facade/roof with joint  (Read 5392 times)
Ricousto
« on: February 06, 2024, 06:27:35 pm »
Newbie with RC and I'm fighting with this example.
What is the best way to do easely this kind of facade/roof with joint ?
Thans in advance
Re: facade/roof with joint
« Reply #1 on: February 07, 2024, 07:49:07 am »
The Auto align option within the Extend X/Y Size to Area mode should help you with this task. This option creates an array aligned automatically with each sub-spline. This feature is very suitable for roofs and panels. Two modes are available. For both modes, the Z axis is always perpendicular to the plane formed by the spline. a) "X --> XY": The X axis is parallel to the RailClone XY plane (considering the local axis of the object). b) "to Spline": The X axis is aligned with the first Spline segment (you can use the "Make first" vertex and "Reverse" spline operations to modify alignment).
To align (overlap) these panels - Segments as needed, using negative Padding (Left & Right) values should do the job.
