Author Topic: A2S with Intersections Macros issue (stuck to mirror mode)  (Read 2954 times)
wezzard
« on: December 10, 2022, 04:39:47 am »
Hi! could someone try to create a simple style using the "A2S with Intersections" macros. I seem to be stuck into mirror mode even if I uncheck "mirror Bottom to top" or "Mirror left to right". I would like to know if it's a bug from the last update or I'm doing something wrong..I haven't use this macro for a long time, but when I did, i'm pretty sure it worked..
Re: A2S with Intersections Macros issue (stuck to mirror mode)
« Reply #1 on: December 12, 2022, 11:03:54 am »
Apologies for that, some time ago a change in RailClone broke some old techniques we used for switches. The attached RailClone Macro file has those issues fixed. You can either load it into a Macro node by right-clicking and selecting Macro > Load From, or you can replace it in your library at the following location
C:\Users\USERNAME\AppData\Local\Itoo Software\RailClone Pro\macros\Generators
I hope that helps,
wezzard
« Reply #2 on: December 20, 2022, 03:06:40 pm »
Thank you Paul!
