Author Topic: Adaptive Mode suggestion  (Read 15507 times)
harumscarum
    • harumscarum's portfolio
« on: January 30, 2014, 12:38:07 pm »
is it possible add support of Corners modes for Adaptive Mode so it will treat segment, not entire spline.
there is solution though - Break vertex, but it is not possible to use Offset in that case
Re: Adaptive Mode suggestion
« Reply #1 on: January 30, 2014, 04:55:40 pm »
Just assign a segment to the Corner rule (an empty segment will work). Without corners, RC handles the spline as an unique section.
harumscarum
« Reply #2 on: January 30, 2014, 05:44:02 pm »
thank you for solution. it works in this specific case - Linear array and no Offset.
below i have Array 2S object and need to ofset it. now i may do it manually Outline spline. if there is any way to add offset and corner support for adaptive mode in array 2s - that would be just great!
