Author Topic: Adding a fencegate to an existing railclone object  (Read 6710 times)
Soluna
« on: March 31, 2021, 02:14:01 pm »
Heyho :)
I found this tutorial a couple of days ago:
https://www.youtube.com/watch?v=zH2bWo4yDxQ&list=PLaHaTGGXkh9vMgNFi0MDa3bMy906oNRmJ&index=4&t=29s
This is exactly the shape I was looking for! Because I´m working on a client project who´s a bit in a hurry I thought I ask here if someone can help me solving this problem:
I used the scene files of that project to create a fence and just modified them a bit. That worked nicely. But now the customer wants a fencegate at a certain position in the fence. I thought I could use markers to be a bit more flexible (just in case he doesn´t like the position where it´s at and wants me to change it). But sadly once I add my modeled fence gate to the marker input in Railclone, it doesn´t really work. Is there any way to fix this without ruining the whole weaving pattern?
Thanks a lot in advance for your help!
Re: Adding a fencegate to an existing railclone object
« Reply #1 on: March 31, 2021, 02:35:14 pm »
As I can see  you are connected to the X evenly instead the X Marker.
Also, for X Marker to work you need to add RC Spline modifier on the Spline and add/set the Marker position.
« Last Edit: March 31, 2021, 02:38:47 pm by Dragan »
Soluna
« Reply #2 on: March 31, 2021, 02:40:47 pm »
In the X evenly of the top generator there´s the Null (that´s from the tutorial file in order to make this setup work) and in the bottom one there´s a branch which I´m using as fence post which has to be in the X evenly cause the posts are evenly distributed. All that works fine. But the gate doesn´t. The gate itself isn´t connected on the screenshot. That´s the 3 nodes on the bottom. When I try to plug them in the X Marker of either the bottom or the top generator, it doesn´t work.
I´m already using the RC Spline modifier and setting up the markers usually works for me but not with this weaving pattern. I attached 2 more screenshots that probably show my setup a bit better.
« Last Edit: March 31, 2021, 02:46:44 pm by Soluna »
« Reply #3 on: March 31, 2021, 02:47:15 pm »
Aha.. sorry I didn't pay attention to the style.
Can you please share the scene for the lower max version, 2018?
Soluna
« Reply #4 on: March 31, 2021, 02:56:16 pm »
Sure! :) I had to upload it to Google Drive. Even though I already removed all of the unnecessary parts of the scene the file is still too big to upload it here.
https://drive.google.com/file/d/1OoqfcMOn3N_GAzafmyHzwBvGcxDqGLhO/view?usp=sharing
Thanks again!!
« Reply #5 on: March 31, 2021, 03:27:58 pm »
Hm, I think this will not work easily with the A2S generator.
I don't have time at the moment to find an easy solution although I think Rokas will find one in few minutes, but I`ll take a look later.
Maybe you could try with Corner input with a unique Vertex type on the spline instedad of markers.
Soluna
« Reply #6 on: March 31, 2021, 03:48:57 pm »
I just tried that with the corner input. Not 100% sure if I did everything correctly but it didn´t really work for me either. The problem is still that the fence is not removed at the area where the fence gate is supposed to be.
But thanks again already!
« Reply #7 on: March 31, 2021, 03:52:09 pm »
You are not using anything to remove the fence:
Soluna
« Reply #8 on: March 31, 2021, 04:15:38 pm »
I´m not sure if I understand what you mean  :(
What should I use to remove the fence? I tried plugging in pretty much everything in the X Marker slot of the top generator but nothing worked :/ With the facade I created it worked when I used the marker. But there I only used the L1S generator and not the L2S.
« Reply #9 on: March 31, 2021, 04:20:26 pm »
You are generating Gates with bottom generator, right ?
Top generator creates fence.
You need gap in fence(top generator) where X marker in gate (bottom generator) are placed. If I understand correctly.
For gaps it is common to use Empty segment with fixed size as the gap.
« Last Edit: March 31, 2021, 04:42:12 pm by Rokas »
Soluna
« Reply #10 on: March 31, 2021, 04:33:48 pm »
The top generator creates the weave pattern. The bottom one is for the fence posts. I tried adding an empty segment but that didn´t work for me.
« Reply #11 on: April 01, 2021, 08:17:17 am »
I think it would be sensible to place gates using Material ID limits instead of the marker.
Soluna
« Reply #12 on: April 01, 2021, 04:31:23 pm »
Hmm yea. That could work. I´ll give that a try! Thanks!!  :)
« Reply #13 on: April 01, 2021, 04:41:11 pm »
Or, you can try with nesting and few L1S...
Soluna
« Reply #14 on: April 03, 2021, 05:54:20 pm »
I have to say that I´m speechless! I´m still pretty new to Railclone and haven´t really worked with the nested generators yet but WOW! That works so perfectly!! I really can´t thank you enough!!!
