Author Topic: Adding mullions in windows  (Read 5187 times)
DamianM
    • MONSUMM
« on: September 12, 2018, 08:06:23 pm »
Hey !
I made parametric windows according to the tutorial on the site and I would like to add one thing that would make my job easier. The point is that mullions would appear in the vertex position, for example in the Bezier curve. I could then manipulate the position and amount of such mullions, unfortunately I have no idea how to do it. Can I count on your help?
Re: Adding mullions in windows
« Reply #1 on: September 13, 2018, 10:26:04 am »
Please attach Your starting scene and describe in more detail what is not happening what You expect.
We will try to help You.
DamianM
    • MONSUMM
« Reply #2 on: September 13, 2018, 07:51:58 pm »
Thank you very much for your answer. I attach the file and explain what is going on. I added a conditional module and a sub-selector for it with mullions. A conditional module has a condition such that when a vertex appears, a muntin should appear, but it does not appear.
I would like to gain the possibility of controlling the number of mullions in the window as well as their number thanks to vertexes.
« Reply #3 on: September 14, 2018, 01:32:53 pm »
Thanks for file. I see You are using clipping spline. There is no reason to use clipping spline in RailClone for rectangular windows.
You lose features and add complexity.
I suggest using two splines X and Y, or even better, just X and use numeric parameter for Y.
Then You will be able to plug X Corner input for Your vertical mullions.
Feel free to follow these threads about windows for more inspiration here, here and here
DamianM
    • MONSUMM
« Reply #4 on: September 14, 2018, 01:51:53 pm »
Thank you Rokas for help, unfortunately your change in my case is unfavorable because the closed lines at the same time are cliping the walls and put in the windows. I need differentiation because in one building there may be windows with different muntins, so I wanted to control them through vertexes.
I would like to create diverse windows on the whole façade using one RC.
« Reply #5 on: September 17, 2018, 02:28:02 pm »
Unfortunately that is not currently possible. Thanks for suggestion though.
