Author Topic: again rounded corner problem  (Read 3539 times)
lukx
    • lukxCGI
« on: January 06, 2016, 12:56:55 pm »
sorry guys to bother you again but again I have problem with rounded corner :(
simple curb form your styles:
https://www.dropbox.com/s/an2ir9ihu3s23k9/curb.max?dl=0
Re: again rounded corner problem
« Reply #1 on: January 06, 2016, 01:40:26 pm »
Unfortunately this is caused by a known limitation when using the Generator > Limit to ID feature on curved splines. Internally each spline section is considered separate so it cannot compute the curves required to create a continuous deformation where the two IDs adjoin. The simplest solution therefore is to add a couple of extra vertices either side of the curved section so that the change starts on a straight section of the pavement. I've attached your file with that change applied.
If this isn't possible there is a workaround that uses Conditional nodes instead of the Limit by ID feature. You can read more about this and download a sample file in this post.
Many thanks!
Paul.
