Author Topic: Aligning pavement pattern to multiple joint splines  (Read 4392 times)
Keith678
« on: November 10, 2022, 10:59:29 am »
Hi amazing people,
I have a urban development which has a particular pavement pattern, 4 different coloured bricks in all (See image 1).
I've divided each pattern into splines, so 4 shapes with multiple splines for each (See image 2).
Now the main issues are:
  • Alignment
  • Some pavements being clipped
As you can see in image 3, the alignment is off I haven't been able to fix it.
Any help on this would be great.
Thanks.
Keith678
Re: Aligning pavement pattern to multiple joint splines
« Reply #1 on: November 10, 2022, 11:51:28 am »
Updated File
« Reply #2 on: November 10, 2022, 06:02:39 pm »
Is the only difference the material colour? If so one option might be to use RailClone Colour with its ability to pick a pixel colour from a map using the surfaces UVs. Here's a short tut about it. https://www.youtube.com/watch?v=s8_XQnP9ftw
That way you could do it in one RailClone object which would eradicate any alignment issues.
Otherwise, to do it as in your file you won't be able to use Extend X/Y Size to area because the arrays won't line up since they're recalculated for each spline. Instead, set an X and Y size for the arrays and make sure they all share the same pivot location. Then use clipping only for the boolean, but not to set the dimensions of the array.
Best,
« Last Edit: November 10, 2022, 06:05:49 pm by Paul Roberts »
Keith678
« Reply #3 on: November 11, 2022, 10:26:52 am »
Hi Paul,
Thanks so much for those two solutions.
I'm going to try the first one now but trying to figure out the best way to create the texture onto the surface.
Any advice on that front?
Thanks.
Keith678
« Reply #4 on: November 11, 2022, 03:40:52 pm »
So,
I've created my texture for colouring by UVing my surface and baking out the texture.
The raiclone is full of errors but getting there ha.
Added MAX file too
« Last Edit: November 11, 2022, 04:38:05 pm by Keith678 »
Keith678
« Reply #5 on: November 11, 2022, 05:28:12 pm »
End of the day now and I don't have more time until Monday to work on this as my PC is getting repaired.
Linking my MAX file of the latest WIP.
If anyone wants to try and fix/improve it I would really appreciate it
« Last Edit: November 11, 2022, 05:37:44 pm by Keith678 »
