Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Animated padding and Vantage
« previous
next »
Print
Pages: [
1
Author
Topic: Animated padding and Vantage (Read 31807 times)
PixelWindChill
Newbie
on:
August 28, 2025, 08:27:06 pm »
I have hit up the Chaos side of things also but I just wanted ask. I have built a train line in RC. I have animated the "Padding" start and it works beautiful on the max side. Train build runs down the spline. When I go to Vantage, this build either only shows up as boxes or doesn't show up at all. When I delete the key frames the RC shows up in Vantage with no issues.
Does anyone know if this is RC thing or a Vantage thing. Are we suppose to have "Use Instancing Engine" off or on? I have tried both animating the Spline Properties where you can check on or off the "Full Length" and control the start and I also as mentioned put it into parameter for the Padding Start. I am not the most advanced user with RC but is there maybe a different way to animate the RC build down a spline where Vantage will not have issues?
Thanks in advance
Murph
Logged
ITOOSOFT
Hero Member
Re: Animated padding and Vantage
Reply #1 on:
August 29, 2025, 12:50:17 pm »
Hi Murph,
Please find attached a sample test scene with a possible style setup that appears to work correctly when using Live Link from 3ds Max. I hope this helps.
Logged
PixelWindChill
Newbie
Reply #2 on:
August 29, 2025, 02:32:57 pm »
Well, I thought this had worked, but once I put key frames and animated the trains, it renders them as boxes in Vantage and some other strange bugs.
Last Edit: August 29, 2025, 04:17:43 pm by PixelWindChill
Logged
PixelWindChill
Newbie
Reply #3 on:
August 29, 2025, 04:19:15 pm »
Keyframes and no keyframes, Vantage just doesn't like these things moving lol
Logged
PixelWindChill
Newbie
Reply #4 on:
August 29, 2025, 04:20:42 pm »
If I find time I will try to package up what I have going on so you guys can maybe investigate the file.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
