Author Topic: Arithmetic parse error  (Read 4300 times)
Macker
« on: November 13, 2019, 05:56:08 pm »
Hi guys, just following your video tutorial for building parametric windows, and I can't get the arithmetic node expression to work at all. I get the following error:
Parse error. Expected ')' or ',' in argument list at line 1:
if(YSplinePosition=0,3,
I've also tried copying and pasting from the text version of the tutorial with the same issue.
Re: Arithmetic parse error
« Reply #1 on: November 13, 2019, 06:01:13 pm »
You are missing one parameter and you have to use `==`
Also you have to start with word Return folowing expression ...
Return
if(YSplinePosition==0,3,_);
https://docs.itoosoft.com/railclone/converting-railclone-2-styles-for-railclone-3
« Last Edit: November 13, 2019, 08:43:28 pm by Dragan »
Macker
« Reply #2 on: November 14, 2019, 11:05:03 am »
Thank you :)
Macker
« Reply #3 on: November 14, 2019, 11:13:40 am »
Hm,
Managed to get rid of the parse error now by adding a parameter that is missing; but it still doesn't work. I'm following this directly from the railclone tutorial here https://www.itoosoft.com/tutorials/parameterise-windows?back=page%3D5%26tag%3Drailclone
Macker
« Reply #4 on: November 14, 2019, 12:16:03 pm »
Here's where I'm at with it
« Reply #5 on: November 25, 2019, 09:45:37 am »
Hi Macker
Tutorial was created for RailClone v2. Expressions were greatly improved in RailClone v3.
The same expression in v3 is written like this:
Code: [Select]
return if(YSplinePosition==0,3,
if(YSplinePosition==1,1,
2));
