Author Topic: Extend X/Y  (Read 11384 times)
funk24
Extend X/Y
« on: March 14, 2014, 01:41:03 pm »
Hello
sorry for my bad english.
I would like to extend with the x / y function a window with a rectangle.
below should still be a profile that is lower than the rectangle.
now I cut the profile rail clone from.
he gives here a solution?
but it must work with the rectangle.
attached nor a print screen.
Thank you.
Re: Extend X/Y
« Reply #1 on: March 14, 2014, 01:51:41 pm »
    Thanks for getting in touch with us. The clipping path uses a boolean operator to slice any geometry that falls outside the boundary, however it may be overridden. Try the following:
    • For the profile segment, turn off Properties>Deform>Slice
    • In the A2S Generator's properties, set the For No Slice option to Preserve
  • If necessary, set the Profile's generator Default Mode to Scale to prevent a segment from overshooting on the sides.
[/list]
I hope that helps,
Many thanks,
« Last Edit: March 14, 2014, 02:01:17 pm by Paul Roberts »
funk24
Re: Extend X/Y
« Reply #2 on: March 14, 2014, 01:58:50 pm »
hi paul
thank you for the quick response!
it works. :)
regards
stefan
Re: Extend X/Y
« Reply #3 on: March 14, 2014, 02:01:58 pm »
Hi Stefan,
Great! Happy to help out  :)
All the best,
