Author Topic: Array 2S - X Evenly Doubling Up The Geometry  (Read 6229 times)
JK3990
« on: August 28, 2017, 08:22:40 pm »
I'm working on a simple window array (3ds max 2017, RailClone Pro 3.0.8), and all seemed to be working fine, except when I rendered, I noticed some really weird shading happening from V-Ray's ambient occlusion, which typically suggests overlapping co-planar faces.  I converted my RailClone to an editable poly and noticed that all of the X Evenly segments are doubled up.  Can anyone explain why this is happening and how I can avoid it?  I'd prefer to not disable AO.  Scene attached.  Thanks!
FC1888
Re: Array 2S - X Evenly Doubling Up The Geometry
« Reply #1 on: August 29, 2017, 02:23:56 am »
Just a guess but I think you are using the Ambient Occlusion setting in Vray's Render Setup.
So just as a test, perhaps you could try setting up AO the way most pros would. As a separate render element
Add a VRay Extra Tex Map into your render elements. Set the map to a VRay dirt map and mess around with the settings until you get the desired result. You can then use this element as a Photoshop layer set to multiply.
Would love to know if you get the same result doing it this way. Though I have a feeling, it's not AO that is the problem here and sadly I don't have 2017 so cannot see for myself, as I use a more stable Max 2014
« Reply #2 on: August 29, 2017, 04:53:51 pm »
Thanks for the provided scene. It's linked to the X Evenly - Extend to Side option. Please find attached modified scene having this option switched off. Null Segment have been added to the corners (to stop Left & Right of having the same issue). Hope you'll find it useful.
JK3990
« Reply #3 on: August 29, 2017, 05:29:13 pm »
@FC Thank you for the suggestion.  I tried as a separate element and still got the same results, but I do see how that method is advantageous as I can tweak the AO in post work if needed.
@Michal Works perfectly, thank you for the solution!
