Author Topic: Array 2S1 Oversize  (Read 4433 times)
HU0164
Array 2S1 Oversize
« on: August 08, 2025, 04:12:01 pm »
Is it possible, using the attached example, to make the red part larger than the base with the same overflow value for all sides?
Re: Array 2S1 Oversize
« Reply #1 on: August 11, 2025, 08:59:11 am »
Thanks for getting in touch. This seems like a good use for the Spline Offset node introduced in RailClone 7. Using that you can create a second generator for the roof and control the amount of overhang by wiring the same spline through the Spline Offset node. Please see the attached sample file for and example of how it can be done.
I hope that helps,
« Reply #2 on: August 12, 2025, 11:04:34 am »
hi Paul,
thanks for the info/ scene & ill check it out
ive attached my test scene & hopefully you can see what im trying to achieve (& match the reference object)
I assume this was posted to the wrong thread?
Cheers,
HU0164
« Reply #3 on: August 25, 2025, 02:17:40 pm »
I hope that helps,
Thank you very much.
Sorry for my late reply, I was on vacation.
HU0164
« Reply #4 on: August 26, 2025, 09:34:01 am »
Is it (or would it be) possible to retrieve the result of the SplineOffset operator as a 3DS Max Spline object?
I can only “see” this Spline with the “Draw Splines” option.
