Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Array on a curved surface
« previous
next »
Print
Pages: [
1
Author
Topic: Array on a curved surface (Read 3195 times)
VanWijnen
Newbie
on:
October 15, 2019, 03:58:01 pm »
I've created a RC object that turns a simple rectangle into a brick street. I can't seem to figure out how to use this RC object on the same surface / spline with a slight curve in it. The Linear1S part works just fine but the Array2S not so much. Could you please point out what I'm doing wrong? I've looked at a lot of tutorials and other threads but I couldn't deduce the answer there.
Logged
Hero Member
Re: Array on a curved surface
Reply #1 on:
October 15, 2019, 04:21:34 pm »
Try to make the surface slightly larger than the clipping spline.
Last Edit: October 15, 2019, 04:52:54 pm by Dragan
Logged
VanWijnen
Newbie
Reply #2 on:
October 16, 2019, 07:22:28 am »
Hi Dragan,
Thanks for the tip! This does bring me closer but it messes the edges up a bit. Any clue on how to fix that?
(Also, apparently the surface has to be in the same postition as the spline to get the right curve)
Logged
ITOOSOFT
Hero Member
Reply #3 on:
October 16, 2019, 08:11:20 am »
Raising the
Clipping Area
Expand
value should fix it.
Logged
VanWijnen
Newbie
Reply #4 on:
October 16, 2019, 08:33:38 am »
That fixed it Michal, thanks!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
