Author Topic: Fixed vs random rotation issue  (Read 2515 times)
« on: February 20, 2020, 08:43:12 am »
Hi. Please check this for me.
Random Z rotation is affected by the next Transform Y_45 deg node (Fixed Z rotation work as expected).
I target all values to 60deg just for the test to see what is going on when switching between FIxed and Random Z rotation.
The real situation is about vine bottles  (rotating bottle for Labels on Z-axis and after that rotate the whole bottle to accommodate shelf angle).
I know the Generator X rotation will do the job but this will go further with Macro Generator/2D stack and individual rotation may be needed so I need to know is this a bug or normal behaviour.
Thank you.
Best Regards
« Last Edit: February 20, 2020, 09:10:23 am by Dragan »
Re: Fixed vs random rotation issue
« Reply #1 on: February 20, 2020, 09:34:19 am »
Hi Dragan,
This is known intentional feature. You can choose which transform behavior You want by either going fixed (chained RC4), or random (accumulated RC3).
« Reply #2 on: February 20, 2020, 10:06:03 am »
Ah, so random remains accumulated in RC4. Got it.
Exported Z-fixed & random parameter with Segment mode works fine.
Thank you for clarify this to me.
Best Regards.
« Last Edit: February 20, 2020, 10:08:34 am by Dragan »
