Author Topic: Herringbone from Multiple Segments  (Read 3714 times)
M55
« on: October 26, 2018, 12:55:51 pm »
i have made some herringbone pavements with 2 segments. getting variation through a material node. that works fine.
now i would like to do a herringbone pavement with some more segments (slates) with different materials and the segments should have a vray displacement Mod on it
is that possible?
A more than 2 segments ... tried everything without success
B. vray displacement mod on each segment... tried everything without success
thanks in advance
Re: Herringbone from Multiple Segments
« Reply #1 on: October 26, 2018, 01:17:30 pm »
A. It should be no problem at all.
"More segments"- should add benefit of new geometry. Use Randomize node to randomize then.
To Randomize material - no new segments should be added. Use Material node tor randomize material.
B. That is not possible. RailClone uses segments geometry- they You see it in the viewport as building blocks.
M55
« Reply #2 on: October 29, 2018, 10:09:10 am »
Thanks Rokas,
silly mistake ... used wrong cloned segments for creation ... now everything works fine.
Good to know about the vray displacement mod ... but no problem.
Thanks for fast response
Klaus
