Author Topic: Can it be used to do something as the intersection  (Read 4030 times)
mitviz
    • mitviz
« on: April 16, 2016, 10:23:47 am »
i have a setting with many roads but idk how to get intersections with railclone, is this even possible?
Professional architectural renders
Re: Can it be used to do something as the intersection
« Reply #1 on: April 18, 2016, 10:45:42 am »
I'm afraid at present RailClone doesn't support joints or intersections. Usually this geometry problem it's difficult to solve even manually, because it requires booleans or other advanced operations. Typically for roads with complex layouts I'll create them simply by meshing closed splines, and then use the same spline to apply Curbs using RailClone.
Many thanks,
mitviz
    • mitviz
« Reply #2 on: April 18, 2016, 10:55:43 am »
hi, yes it seems i will have to keep working that way too
