Author Topic: curtain wall and corners  (Read 3205 times)
mitviz
    • mitviz
« on: April 19, 2016, 09:17:08 am »
hi, how do i get a better corner when using the curtain wall on a curved spline? for now it looks like this, edges look flared off
Professional architectural renders
Re: curtain wall and corners
« Reply #1 on: April 19, 2016, 11:44:07 am »
From your picture is looks as though the corner is defined by a number of vertices and each of these is generating a corner segment. In RailClone you can define what types of vertex generate a corner segment using the Vertex Type dropdown.
If the style is currently creating a segment on Corner or Corner-Bezier vertices you could change the base spline so that it doesn't use either of these types. Alternatively you can use this dropdown to change the vertex types that generate a corner segment. For Example Change this to Corner to stop it adding segments on Bezier-Corner vertices.
Many Thanks,
