Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
RC (and FPP) Toolbars changed?
« previous
next »
Print
Pages: [
1
Author
Topic: RC (and FPP) Toolbars changed? (Read 5145 times)
TL1895
Sr. Member
on:
January 29, 2024, 05:51:31 pm »
Did the toolbars get de-volved a bit?
There are only buttons to create them now...
I really miss the "Listers"
max2019
windows10
current v-ray
Thank you,
TL1895
Logged
ITOOSOFT
Hero Member
Re: RC (and FPP) Toolbars changed?
Reply #1 on:
January 30, 2024, 09:32:59 am »
These haven't changed. Are you using any 3ds max's Custom UI Scheme? I would suggest you "reset" 3ds max by deleting your User files. To remove the user profile:
Ensure that the 3ds max is not running.
Navigate to the following path:
C:\Users\%yourUsername%\AppData\Local\Autodesk\3dsMax\2019 - 64bit\ENU
Rename the ENU folder to ENU_Old.
When 3ds max is launched a new ENU folder will be created. If the issue has not been resolved, you can revert to the previous settings by deleting the new ENU folder and renaming the old one back to what it was.
Logged
TL1895
Sr. Member
Reply #2 on:
February 01, 2024, 01:33:09 pm »
Thanks, I will give it a try...
Logged
TL1895
Sr. Member
Reply #3 on:
February 01, 2024, 08:21:43 pm »
Quote from: TL1895 on February 01, 2024, 01:33:09 pm
Somehow, my max UI scheme was corrupt.
I did the "reset" re-customized UI and now it's all working as expected!
Thanks for the tip,
TL1895
Logged
ITOOSOFT
Hero Member
Reply #4 on:
February 02, 2024, 08:08:06 am »
You're welcome. I'm glad to hear that it helped.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
