Author Topic: What is the official line direction to get correct results.  (Read 2730 times)
BK8837
What is the official line direction needed to get the correct results in RailClone?
I have been doing it like this as a rule, in reading direction from top view. I been having issues of models arraying in the opposite direction. I know can reverse the line, but I was wondering if Itoo has a golden rule for the direction of spline creation.
Thank you.
« Last Edit: April 18, 2023, 04:47:17 am by BK8837 »
Re: What is the official line direction to get correct results.
« Reply #1 on: April 18, 2023, 10:20:52 am »
That depends of the selected option in Generator->Clipping Area->Auto align:
None: array is aligned with the local axis of the RailClone object (X, Y and Z).
X --> XY: similar to 'None', but Z is perpendicular to the Spline.
To Spline: X axis is aligned with the Spline's first segment (you can use Make first vertex and Reverse spline to modify alignment).
