Author Topic: Corners for acute/obtuse /inside/outside  (Read 2544 times)
Troy_1234
« on: April 18, 2023, 10:37:09 am »
I'm trying to get these corner mullions to sit correctly, on the inside corners it sits correctly but on the outside corners it does not. What's the best solution to correct this? Do I need a conditional operator?
Re: Corners for acute/obtuse /inside/outside
« Reply #1 on: April 18, 2023, 11:21:11 am »
Thanks for your question. Please try the following
- First rotate the geometry for the corner segment so that it's not at 45 degrees and reset the XForm
- Next, turn on Generator > rules > Corner > Alight to path. This will add the 45 degree rotation correctly by bisecting the angle of the corner
I hope that helps,
Troy_1234
« Reply #2 on: April 18, 2023, 11:36:50 am »
Magic, thanks Paul!
