Author Topic: Escalator - solid Step problem  (Read 3008 times)
ST3200
« on: June 09, 2021, 06:11:42 pm »
I wanted to make an Escalator, but I had a problem with steps : all was flat as ski jump.
I had to change a value in graph window. It seems that it is the Walkway value ( bool ) that have no effect.
It is a bug ? I'm the only one ?
Thanks.
« Last Edit: June 09, 2021, 06:14:03 pm by ST3200 »
Re: Escalator - solid Step problem
« Reply #1 on: June 09, 2021, 06:30:28 pm »
if your Walkway parameter is Type boolean then the output will be 0 or 1 and the selector starts with value 1.
So you just add an arithmetic node after the Walkway parameter and add a constant parameter with value 1.
« Last Edit: June 09, 2021, 06:34:55 pm by Dragan »
ST3200
« Reply #2 on: June 10, 2021, 08:22:14 am »
Hi, Dragan thanks for answer.
But in fact it is the "Escalator - solid"  from itoo presets... I can't manage to make steps when checking "Walkway".
So I wonder if there is a problem with the bool node.
« Reply #3 on: June 10, 2021, 10:27:08 am »
Yes, same thing.
Those styles were made in previous versions.
Try to set Walkway type to integer and set value=2
ST3200
« Reply #4 on: June 10, 2021, 10:58:01 am »
Thanks.
Hope Itoo fix this....
