Author Topic: Catenary Operator  (Read 5587 times)
arch3d
    • arch3d.pl
Catenary Operator
« on: November 10, 2025, 03:28:37 am »
I got some quesion. Is it possible to limit catenary spline operatot to get ellipse to some point than got regular lowered array?
Many thanks
Michal
Re: Catenary Operator
« Reply #1 on: November 10, 2025, 09:31:24 am »
Hi Michal,
Please find attached a modified version of your scene (251110_scene_ITOOSOFT.max), where I used the Padding operation to 'split' the spline into sections, made the middle part linear with the Normalize operation, and then combined everything back together. I hope this helps.
arch3d
    • arch3d.pl
« Reply #2 on: November 10, 2025, 02:05:48 pm »
Michal,
Thank you very much. I miss hov to combine splines :)
Its perfect!
arch3d
    • arch3d.pl
« Reply #3 on: November 11, 2025, 05:20:38 am »
Michal,
One more question.
How about using absolute values not realtive?
Many thanks
Michal
« Reply #4 on: November 11, 2025, 10:42:56 am »
You can adjust the Absolute values for the Padding operations. Just keep in mind that for the Start & End and Start/End modes, the values should match just like in the case of Relative values set to 80% and 20%.
