Author Topic: Changing Evenly distance by Spline parameters  (Read 2973 times)
Victor Gan
« on: August 30, 2019, 07:12:48 am »
Hi all,
  Been using railclone for 2 years and for the first time I have a problem I can't get my head around.
  I need the window mullions in my railclone to appear at different frequencies depending on whether they're being generated on a straight line or a curve; curves need more segments as the glass can't be bent to conform to the curve.
  Is there any way to change Evenly distance depending on Spline parameters like line/curve type, vertex type or MatID?
  For my array I've tried using all of the above in an Arithmetic plugged into the generator's X Evenly Distance param, but none seem to work.
  Screenies attached.
« Last Edit: August 30, 2019, 07:16:05 am by ID2296 »
Re: Changing Evenly distance by Spline parameters
« Reply #1 on: August 30, 2019, 07:52:38 am »
Hi!
Evenly is special distance. It is calculated once and applied throughout the spline at regular intervals.
Default input is more flexible:
Victor Gan
« Reply #2 on: September 02, 2019, 02:47:09 am »
Hi!
Thanks Rokas, it's very helpful to understand the true behaviour of Evenly.
I'll report back my progress.
