Author Topic: Differences in shading in Railclone bamboo pergola  (Read 3512 times)
DN1876
« on: May 25, 2022, 10:49:40 am »
I would like to ask if someone has a tip how I could fix the difference in shading.
The Railclone setup is for the bamboo sticks fpr the pergola. Each pergola has its own linear 1s generator sharing the same segments (see attached image)
Thank you for your time!
Re: Differences in shading in Railclone bamboo pergola
« Reply #1 on: May 25, 2022, 12:37:42 pm »
I can't seem to open your second image that shows the problem. Would you mind uploading it again?
DN1876
« Reply #2 on: May 25, 2022, 04:57:06 pm »
Yes, I am sorry I didn't notice it was 0 kb.
« Last Edit: May 26, 2022, 02:21:16 pm by DN1876 »
DN1876
« Reply #3 on: June 05, 2022, 01:22:37 pm »
Do you have any info on this shading diffrence? Even if I reverse the 1s generator I get a difference in shade (upper left corner).
Thanks in advance.
« Reply #4 on: June 06, 2022, 09:39:24 am »
It's very hard to tell from the picture what might be the issue. It looks as though there are coplanar polys. Is it possible that double geometry is being created in that area? If you can isolate the problem in a simplified scene file and send it to use we might be able to help further.
DN1876
« Reply #5 on: June 07, 2022, 10:34:49 am »
I am attaching the scene simplified.
https://we.tl/t-nYLBpS4Zai
Thank you for your time and effort.
Kind Regards,
Giorgos
« Reply #6 on: June 07, 2022, 02:51:18 pm »
Hi Giorgos,
Thanks for the file. It would appear to be related to the smoothing groups of the segments. That particular section has the pieces the other way up from the others, and I think the smoothing groups are causing the bottom of the source geometry to shade slightly differently from the top. I found that selecting all the bamboo source objects and adding a Smooth modifier set to smoothing group 1 fixed it.
I hope that helps,
Paul.
DN1876
« Reply #7 on: June 07, 2022, 03:06:08 pm »
Thank you very much for your reply, I will check it and i will post the results here just in case someone has the same problem in the future.
