Author Topic: Classical Facade with Railclone  (Read 11587 times)
Anthony Lester
« on: July 16, 2025, 07:58:00 pm »
Hi, this is going back a bit but I wonder if there is a more detailed tutorial that goes into the set-up of the scene used in https://www.itoosoft.com/tutorials/creating-patterns
I am just about to start modelling Regent street in central London which has similar classical facades and remembered this 10 second tip.
fingers crossed
Anthony
Re: Classical Facade with Railclone
« Reply #1 on: July 17, 2025, 09:35:51 am »
Hi Anthony,
I would suggest checking out the ‘Randomising Shop Fronts and Facades’ tutorial, together with the ‘Create a Building Generator and Master the A2S Generator’ tutorial. These should help you build your own facade style using Sequence Operators. I hope this helps.
