Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Cladding and windows cut out
« previous
next »
Print
Pages: [
1
Author
Topic: Cladding and windows cut out (Read 4858 times)
smckenzie
Newbie
on:
November 02, 2023, 04:25:15 pm »
Total newbie here.
I have cladding on a wall but the windows are not fully cut out. I've tried reversing the window splines, changing hierarchy mode and resetting xform.
Any help is appreciated.
Logged
ITOOSOFT
Hero Member
Re: Cladding and windows cut out
Reply #1 on:
November 02, 2023, 04:30:56 pm »
I would suggest using the
Realign
button (
Base Objects
Properties
Realign
) to see if that helps. If that doesn't fix it, if possible, please feel free to
send us
your scene (ideally simplified and containing just this problematic object(s)). Thanks in advance.
Logged
smckenzie
Newbie
Reply #2 on:
November 02, 2023, 04:56:18 pm »
thanks for the fast reply.
that didn't work. attached a file.
Logged
ITOOSOFT
Hero Member
Reply #3 on:
November 03, 2023, 08:25:06 am »
Thank you for providing the scene. Switching the
Hierarchy Mode
parameter to
3
within the
Cladding
macro does the trick. Please find attached the modified version of your scene (
231103_cladding_iToo.max
Logged
smckenzie
Newbie
Reply #4 on:
November 03, 2023, 05:56:48 pm »
That doesn't make any sense. It's on 3 by default and didn't work but it does when the geo is separated into a separate file.
You can see on the attached screenshot it's not working (with the main model).
Logged
smckenzie
Newbie
Reply #5 on:
November 03, 2023, 06:04:07 pm »
Ok, so I got this to work. Basically have to reverse each window spline and then realign the base object.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
