Author Topic: Clipping spline typo in help file  (Read 2816 times)
Pixelab
  • Suave mari magno
    • pixelab.be
« on: February 07, 2017, 06:35:01 pm »
Rule 3 - The Projection axis relates to the local pivot system of the RailClone object - not the spline's or world's axes.
is actually
Rule 3 - The Projection axis relates to the orientation (bounding box) of the RailClone object - not the spline's or world's axes.
which is (unfortunately) not the same... changing the pivot doesn't have any effect. I would actually be nice that RC behaves like the help description, pivot is much more easier to modify in max than BB/ object orientation
Re: Clipping spline typo in help file
« Reply #1 on: February 07, 2017, 06:38:31 pm »
HI,
Thanks for letting us know. You're right that point could be made clearer. I'll amend the documentation.
Appreciate the feedback,
Pixelab
  • Suave mari magno
    • pixelab.be
« Reply #2 on: February 07, 2017, 07:36:18 pm »
You're welcome
also, you can cahnge
RailClone's clipping is considerably more efficient than using 3DS Max's boolean operations
to
RailClone's clipping is considerably more efficient, faster and robust than using 3DS Max's boolean operations :)
« Reply #3 on: February 07, 2017, 07:49:46 pm »
He he - thanks.
